Jiayuan Eidola EV
Hello, I’m looking for help.
I have a Jiayuan Eidola EV car. I was on holiday for one month and the car was not charged during that time. Now the car has no power.
When I plug in the charger, the dashboard light blinks red and green, and the charging indicator is also red. When I turn on the car and try to use anything (lights, horn, gear, etc.), the controller makes a ticking noise (“tik tik tik”), and after a while it makes a beeping sound. The car does not respond and none of the functions work.
I tried to find a 12V starter battery to jump-start it, but I couldn’t find one under the seat, in the front, or in the back. I also considered jumping the controller, but I read that it can be dangerous because it is 72V / 400A.
The car is from 2022, has only about 500 km, and the battery was always in good condition before this.
Does anyone know what the problem could be or what I should do? Could it be related to the BMS, or does this car have a hidden 12V battery?
Thank you very much for any help.
